Zum Hauptinhalt wechseln
Dell Inspiron 1320 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 1320 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Disconnect the display cable and the camera cable from their respective system board connectors.
  2. Dell Inspiron 1320 Display Assembly Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  3. Dell Inspiron 1320 Display Assembly Replacement, Dislodging the Antenna Cables: Schritt 3, Bild 1 von 1
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Lift the display assembly off the computer.
  4. Dell Inspiron 1320 Display Assembly Replacement, Placing the Display Assembly: Schritt 5, Bild 1 von 1
    • Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
    • Route the Mini-Card antenna cables through the routing guides.
  5. Dell Inspiron 1320 Display Assembly Replacement, Connecting the Display Cable: Schritt 7, Bild 1 von 1
    • Connect the display cable and the camera cable to their respective system board connectors.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 264
