Zum Hauptinhalt wechseln
Dell Inspiron 13z 5323 Battery Replacement
Was du brauchst
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 13z 5323 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 13z 5323 Battery Replacement: Schritt 2, Bild 3 von 3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13z 5323 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13z 5323 Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 13z 5323 Battery Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 13z 5323 Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
Abschluss
Chase Hussey
201 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S5-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G6
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 883
