Einleitung
In this guide, we will show you how to remove and replace the Hard Drive.
Was du brauchst
Remove the screws that secure the hard-drive assembly to the computer base.
Disconnect the hard-drive cable connector from the hard-drive assembly.
Lift the hard-drive assembly away from the computer base.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Connect the hard-drive cable connector to the hard-drive assembly.
Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
