Zum Hauptinhalt wechseln
Dell Inspiron 13z 5323 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: Schritt 2, Bild 1 von 2 Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: Schritt 2, Bild 2 von 2
    • Disconnect the hard-drive cable connector from the hard-drive assembly.
  3. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly away from the computer base.
  4. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: Schritt 5, Bild 1 von 2 Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: Schritt 5, Bild 2 von 2
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: Schritt 6, Bild 1 von 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: Schritt 8, Bild 1 von 2 Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: Schritt 8, Bild 2 von 2
    • Connect the hard-drive cable connector to the hard-drive assembly.
  9. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: Schritt 9, Bild 1 von 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  10. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Abschluss
Terrence15
79.309 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.984 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 620
