Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Follow the instructions in Before You Begin.
    • Follow the instructions in Before You Begin.
    • Turn the computer over.
    • Disconnect the Mini-Card antenna cables from the computer base.
  2. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
  3. Disconnect the display cable and the camera cable from their connectors on the system board.
    • Disconnect the display cable and the camera cable from their connectors on the system board.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Make a note of the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
    • Make a note of the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
  6. Remove the six screws (three on each side) that secure the display assembly to the computer base.
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  7. Lift and remove the display assembly off the computer base.
    • Lift and remove the display assembly off the computer base.
  8. Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base. Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base.
  9. Route the Mini-Card antenna cables through the slot on the computer base.
    • Route the Mini-Card antenna cables through the slot on the computer base.
  10. Connect the display cable and the camera cable to their connectors on the system board.
    • Connect the display cable and the camera cable to their connectors on the system board.
Ziellinie
Terrence15
72.040 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
21 Mitglieder
1.816 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 61
