Zum Hauptinhalt wechseln
Einleitung
In this guide, we will be showing you how to remove and replace the Hard-Drive Assembly.
Ersatzteile
Keine Ersatzteile angegeben.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
    • Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
  3. Lift the hard-drive assembly out of the computer base.
    • Lift the hard-drive assembly out of the computer base.
  4. Remove the four screws that secure the hard-drive bracket to the hard drive.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Lift the hard drive out of the hard-drive bracket. Lift the hard drive out of the hard-drive bracket.
    • Lift the hard drive out of the hard-drive bracket.
  6. Pull the interposer to disconnect it from the hard drive.
    • Pull the interposer to disconnect it from the hard drive.
  7. Connect the interposer to the NEW hard drive.
    • Connect the interposer to the NEW hard drive.
  8. Place the hard drive in the hard-drive bracket. Place the hard drive in the hard-drive bracket.
    • Place the hard drive in the hard-drive bracket.
  9. Replace the four screws the hard-drive bracket to the hard drive.
    • Replace the four screws the hard-drive bracket to the hard drive.
  10. Place the hard-drive assembly in the computer base.
    • Place the hard-drive assembly in the computer base.
  11. Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
    • Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
  12. Replace the four screws that secure the hard-drive assembly to the computer base.
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Ziellinie
Terrence15
71.356 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
926 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 58
