Zum Hauptinhalt wechseln
Dell Inspiron 13z N311z Battery Replacement
  1. Dell Inspiron 13z N311z Battery Replacement, Popping out the Battery: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
    • Slide both the battery release latches to the unlock position. The battery pops out of the battery bay.
  2. Dell Inspiron 13z N311z Battery Replacement, Lifting the Battery: Schritt 2, Bild 1 von 1
    • Lift the battery out of the battery bay. After the battery is removed, the left battery latch must be in the locked position.
Abschluss
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 152
