Zum Hauptinhalt wechseln
Dell Inspiron 13z N311z Hard-Drive Assembly Replacement
Was du brauchst
  1. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Remove the Screw: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the screw that secures the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Bracket: Schritt 2, Bild 1 von 1
    • To avoid damage to the hard drive, gently slide the hard-drive bracket away from the hard-drive slot.
  3. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Lift the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Removing the Screws: Schritt 4, Bild 1 von 1
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Lifting the Hard Drive: Schritt 5, Bild 1 von 2 Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Lifting the Hard Drive: Schritt 5, Bild 2 von 2
    • Lift the hard drive out of the hard-drive bracket.
  6. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Align the Screw Holes: Schritt 6, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: Schritt 8, Bild 1 von 1
    • Place the NEW hard-drive assembly in the computer base.
  9. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: Schritt 9, Bild 1 von 1
    • Slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Replace the Screw: Schritt 10, Bild 1 von 1
    • Replace the screw that secures the hard-drive assembly to the computer base.
Ziellinie
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 238
