Zum Hauptinhalt wechseln
Dell Inspiron 14 3459 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 14 3459 Display Assembly Replacement, Sliding the Antenna Cables: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Close the display and turn the computer over.
    • Slide the antenna cables into the slot on the computer base.
  2. Dell Inspiron 14 3459 Display Assembly Replacement, Disconnecting the I/O Board Cable: Schritt 2, Bild 1 von 2 Dell Inspiron 14 3459 Display Assembly Replacement, Disconnecting the I/O Board Cable: Schritt 2, Bild 2 von 2
    • Turn the computer over and open the display.
    • Open the latch and disconnect the I/O-board cable from the I/O board.
  3. Dell Inspiron 14 3459 Display Assembly Replacement, Removing the Board Cable: Schritt 3, Bild 1 von 1
    • Remove the I/O-board cable from the computer base.
  4. Dell Inspiron 14 3459 Display Assembly Replacement, Remove the Antenna Cables: Schritt 4, Bild 1 von 1
    • Note the antenna cable routing and remove the antenna cables from the routing guides on the computer base.
  5. Dell Inspiron 14 3459 Display Assembly Replacement, Note the Routing: Schritt 5, Bild 1 von 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  6. Dell Inspiron 14 3459 Display Assembly Replacement, Remove the Screws: Schritt 6, Bild 1 von 1
    • Remove the screws that secure the display hinges to the computer base.
  7. Dell Inspiron 14 3459 Display Assembly Replacement, Lift the Display Assembly: Schritt 7, Bild 1 von 1
    • Lift the display assembly off the computer base.
  8. Dell Inspiron 14 3459 Display Assembly Replacement, Align the Screw Holes: Schritt 8, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  9. Dell Inspiron 14 3459 Display Assembly Replacement, Replace the Screws: Schritt 9, Bild 1 von 1
    • Replace the screws that secure the display hinges to the computer base.
  10. Dell Inspiron 14 3459 Display Assembly Replacement, Route the Display Cable: Schritt 10, Bild 1 von 1
    • Route the display cable through the routing guides on the computer base.
  11. Dell Inspiron 14 3459 Display Assembly Replacement, Route the Antenna Cables: Schritt 11, Bild 1 von 1
    • Route the antenna cables through the routing guides on the computer base and slide the antenna cables through the slot on the computer base.
  12. Dell Inspiron 14 3459 Display Assembly Replacement, Sliding the I/O Board Cable: Schritt 12, Bild 1 von 1
    • Slide the I/O-board cable into the I/O board and close the latch to secure the cable.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 592
