Zum Hauptinhalt wechseln
Dell Inspiron 14 3459 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 14 3459 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 3459 Hard Drive Replacement, Disconnect the Hard Drive Cable: Schritt 2, Bild 1 von 2 Dell Inspiron 14 3459 Hard Drive Replacement, Disconnect the Hard Drive Cable: Schritt 2, Bild 2 von 2
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 14 3459 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14 3459 Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 3459 Hard Drive Replacement, Lifting the Hard-Drive Bracket: Schritt 5, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 3459 Hard Drive Replacement, Disconnecting the Interposer: Schritt 6, Bild 1 von 1
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3459 Hard Drive Replacement, Connecting the Interposer: Schritt 7, Bild 1 von 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3459 Hard Drive Replacement, Align the Screw Holes: Schritt 8, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 3459 Hard Drive Replacement, Replace the Screws: Schritt 9, Bild 1 von 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 3459 Hard Drive Replacement, Align the Screw Holes: Schritt 10, Bild 1 von 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 3459 Hard Drive Replacement, Replace the Screws: Schritt 11, Bild 1 von 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 3459 Hard Drive Replacement, Securing the Hard Drive Cable: Schritt 12, Bild 1 von 2 Dell Inspiron 14 3459 Hard Drive Replacement, Securing the Hard Drive Cable: Schritt 12, Bild 2 von 2
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Ziellinie
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,246
