Zum Hauptinhalt wechseln
Dell Inspiron 14 3462 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 14 3462 Display Assembly Replacement, Peel the Tape: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 14 3462 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 2, Bild 1 von 1
    • Open the latch that secures the display cable into position.
    • Disconnect the display cable from the system board.
  3. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Antenna Cable: Schritt 3, Bild 1 von 1
    • Note the antenna-cable routing, and remove the antenna cable from the routing guides on the palm-rest assembly.
  4. Dell Inspiron 14 3462 Display Assembly Replacement, Turn the Computer Over: Schritt 4, Bild 1 von 1
    • Turn the computer over and open the display at an angle of 90 degrees.
    • Turn the computer over and place it on the edge of the table in a position that allows access to the screws on the display hinges.
  5. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the three screws (M2.5x8) that secure the display-hinge brackets to the palm-rest assembly.
  6. Dell Inspiron 14 3462 Display Assembly Replacement, Lifting the Display Assembly: Schritt 6, Bild 1 von 1
    • Carefully lift the display assembly from the palm-rest assembly.
  7. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 1 von 1
    • Carefully place the display assembly on a clean and flat surface.
  8. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: Schritt 8, Bild 1 von 1
    • Place the NEW display assembly at the edge of the table.
  9. Dell Inspiron 14 3462 Display Assembly Replacement, Align the Screw Holes: Schritt 9, Bild 1 von 1
    • Align the screw holes on the palm-rest assembly with the screw holes on the display hinges.
  10. Dell Inspiron 14 3462 Display Assembly Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the three screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 14 3462 Display Assembly Replacement, Route the Cables: Schritt 11, Bild 1 von 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 14 3462 Display Assembly Replacement, Connecting the Display Cable: Schritt 12, Bild 1 von 1
    • Connect the display cable from the system board.
  13. Dell Inspiron 14 3462 Display Assembly Replacement, Close the Latch: Schritt 13, Bild 1 von 1
    • Close the latch that secures the display cable to the system board.
  14. Dell Inspiron 14 3462 Display Assembly Replacement, Adhering the Tape: Schritt 14, Bild 1 von 1
    • Adhere the tape that secures the display cable to the system board.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 212
