Einleitung
How To Remove And Replace The Hard-Drive
Was du brauchst
Open the latch, and disconnect the hard-drive cable from the connector on the system board.
Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Lift the hard-drive assembly along with its cable off the palm-rest assembly.
Remove the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
Lift the hard-drive assembly off the hard-drive bracket.
Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
Replace the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
