Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
How to remove and replace the Hard-Drive.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the screws that secure the hard-drive assembly to the computer base.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Open the latch and disconnect the hard-drive cable from the system board.
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Lift the hard-drive assembly off the computer base.
    • Lift the hard-drive assembly off the computer base.
  4. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Lift the hard-drive bracket off the hard drive.
    • Lift the hard-drive bracket off the hard drive.
  6. Disconnect the interposer from the hard drive.
    • Disconnect the interposer from the hard drive.
  7. Connect the interposer to the NEW hard drive.
    • Connect the interposer to the NEW hard drive.
  8. Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Replace the screws that secure the hard-drive bracket to the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Replace the screws that secure the hard-drive assembly to the computer base.
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Slide the hard-drive cable into the system board and close the latch to secure the cable.
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
darrius
5.072 Reputation
30 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
18 Mitglieder
1.816 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 46
