Zum Hauptinhalt wechseln
Dell Inspiron 14 5100 Motherboard Replacement
Was du brauchst
  1. Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: Schritt 1, Bild 1 von 3 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: Schritt 1, Bild 2 von 3 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: Schritt 1, Bild 3 von 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Motherboard Replacement, RAM: Schritt 3, Bild 1 von 1
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
  6. Dell Inspiron 14 5100 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Detach the white connector from the motherboard using the spudger.
  7. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Flip up the retaining flap and remove the blue ribbon cable from its connector on the motherboard using a spudger.
  8. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Flip up the retaining flap and remove the orange ribbon cable from its connector on the motherboard using a spudger.
  9. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Detach the CMOS battery connector using the spudger.
  10. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the black connector using the spudger.
  11. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the single 3 mm screw from the Wi-Fi card using the Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of the slot and set aside.
  12. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the single screw from the SSD using the Phillips #0 screwdriver.
    • Remove the SSD from the motherboard.
  13. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Remove two 2 mm screws using the Phillips #0 screwdriver.
  14. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 14, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Disconnect the cable from its connector on the motherboard using the spudger.
  15. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Lift the metal retaining flap using the opening tool.
    • Remove the connector from the bracket.
  16. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 16, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Detach the cable using the spudger.
  17. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 17, Bild 1 von 2 Dell Inspiron 14 5100 Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Detach the connector using the spudger.
  18. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Remove six 3 mm screws using the Phillips #0 screwdriver.
  19. Dell Inspiron 14 5100 Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Remove the motherboard by lifting it from the rear and then completely removing it from the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 673
