Zum Hauptinhalt wechseln
Dell Inspiron 14 7447 Battery Replacement
  1. Dell Inspiron 14 7447 Battery Replacement, Sliding the Release Latches: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Close the display and turn the computer over.
    • Slide the battery-release latches to the unlock position.
  2. Dell Inspiron 14 7447 Battery Replacement, Lifting the Battery: Schritt 2, Bild 1 von 2 Dell Inspiron 14 7447 Battery Replacement, Lifting the Battery: Schritt 2, Bild 2 von 2
    • Using your fingertips, lift the battery at an angle and remove the battery off the computer base.
  3. Dell Inspiron 14 7447 Battery Replacement, Grounding the System Board: Schritt 3, Bild 1 von 1
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board.
  4. Dell Inspiron 14 7447 Battery Replacement, Inserting the Battery: Schritt 4, Bild 1 von 1
    • Insert the NEW battery at an angle into the battery bay and align the tabs on the battery with the slots on the battery bay.
  5. Dell Inspiron 14 7447 Battery Replacement, Press the Battery Down: Schritt 5, Bild 1 von 1
    • Press the battery down until it snaps into place.
  6. Dell Inspiron 14 7447 Battery Replacement, Opening the Display: Schritt 6, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
Abschluss
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 971
