Einleitung
In this guide, we will show you how to remove and replace the Battery.
Was du brauchst
Disconnect the battery cable from the system board.
Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Grounding the System Board is required after removing battery?
