Zum Hauptinhalt wechseln
Dell Inspiron 14 7460 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 14 7460 Display Assembly Replacement, Remove the Antenna Cables: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Note the routing and remove the antenna cables from the routing guides on the fan.
  2. Dell Inspiron 14 7460 Display Assembly Replacement, Disconnecting the Display Cables: Schritt 2, Bild 1 von 1
    • Open the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 14 7460 Display Assembly Replacement, Placing the Computer: Schritt 3, Bild 1 von 1
    • Open the display at an angle of 90 degrees.
    • Place the computer on the edge of a table so that the palm rest and keyboard assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  4. Dell Inspiron 14 7460 Display Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws (M2.5x5) that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 14 7460 Display Assembly Replacement, Lifting the Display Assembly: Schritt 5, Bild 1 von 2 Dell Inspiron 14 7460 Display Assembly Replacement, Lifting the Display Assembly: Schritt 5, Bild 2 von 2
    • Lift the display assembly off the palm rest and keyboard assembly.
  6. Dell Inspiron 14 7460 Display Assembly Replacement, Placing the Palm Rest: Schritt 6, Bild 1 von 1
    • Place the palm rest and keyboard assembly on the edge of a table with the keyboard facing down.
  7. Dell Inspiron 14 7460 Display Assembly Replacement, Align the Screw Holes: Schritt 7, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  8. Dell Inspiron 14 7460 Display Assembly Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the four screws (M2.5x5) that secure the NEW display assembly to the palm rest and keyboard assembly.
  9. Dell Inspiron 14 7460 Display Assembly Replacement, Securing the Display Cable: Schritt 9, Bild 1 von 1
    • Close the display and turn the computer over.
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  10. Dell Inspiron 14 7460 Display Assembly Replacement, Routing the Antenna Cables: Schritt 10, Bild 1 von 1
    • Route the antenna cables through the routing guides on the fan.
Abschluss
Terrence15
79.243 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,501
