Zum Hauptinhalt wechseln
Dell Inspiron 14 7460 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 14 7460 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions inAfter Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 14 7460 Hard Drive Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  3. Dell Inspiron 14 7460 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the palm rest and keyboard assembly.
  4. Dell Inspiron 14 7460 Hard Drive Replacement, Disconnecting the Interposer: Schritt 4, Bild 1 von 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 14 7460 Hard Drive Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 14 7460 Hard Drive Replacement, Lifting the Hard-Drive: Schritt 6, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  7. Dell Inspiron 14 7460 Hard Drive Replacement, Align the Screw Holes: Schritt 7, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 14 7460 Hard Drive Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 14 7460 Hard Drive Replacement, Connecting the Interposer: Schritt 9, Bild 1 von 1
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 14 7460 Hard Drive Replacement, Align the Screw Holes: Schritt 10, Bild 1 von 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  11. Dell Inspiron 14 7460 Hard Drive Replacement, Replace the Screws: Schritt 11, Bild 1 von 1
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  12. Dell Inspiron 14 7460 Hard Drive Replacement, Connecting the Hard-Drive Cable: Schritt 12, Bild 1 von 1
    • Connect the hard-drive cable to the system board.
Abschluss
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 19
Insgesamt: 2,338
