Zum Hauptinhalt wechseln
Dell Inspiron 14 Gaming 7466 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Camera Cable: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peeling the Camera Cable: Schritt 2, Bild 1 von 1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Antenna Cables: Schritt 3, Bild 1 von 1
    • Remove the antenna cables from the routing guides on the computer base.
  4. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screw: Schritt 4, Bild 1 von 1
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  5. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Cable Bracket: Schritt 5, Bild 1 von 1
    • Lift the display-cable bracket off the system board.
  6. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 6, Bild 1 von 1
    • Using the pull-tab, disconnect the display cable from the system board.
  7. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peel off the Display Cable: Schritt 7, Bild 1 von 1
    • Peel off the display cable from the computer base.
  8. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: Schritt 8, Bild 1 von 1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: Schritt 9, Bild 1 von 1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Open the Display: Schritt 10, Bild 1 von 1
    • Turn the computer over and open the display.
  11. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: Schritt 11, Bild 1 von 1
  12. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Assembly: Schritt 12, Bild 1 von 1
    • Lift the display assembly off the computer base.
  13. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Holes: Schritt 13, Bild 1 von 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  14. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: Schritt 14, Bild 1 von 1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: Schritt 15, Bild 1 von 1
    • Close the display and turn the computer over.
  16. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: Schritt 16, Bild 1 von 1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  17. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Adhering the Cables: Schritt 17, Bild 1 von 1
    • Adhere the display cable and the camera cable to the computer base.
  18. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Connect the Display Cable: Schritt 18, Bild 1 von 1
    • Connect the display cable and camera cable to the system board.
  19. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Hole: Schritt 19, Bild 1 von 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  20. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screw: Schritt 20, Bild 1 von 1
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 107
