Einleitung
In this guide, we will show you how to remove and replace the Display Assembly.
Was du brauchst
Disconnect the display cable from the connector on the system board.
Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
Remove the two screws that secure the display assembly to the computer base.
Lift and remove the display assembly out of the computer base.
Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
Route the display cable and Mini-Card antenna cables through the routing guides.
Connect the display cable to the connector on the system board.
