Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. WARNING: Before working inside your computer, read the safety information  that shipped with your computer. Follow the instructions in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Lift the hard-drive assembly out of the computer base.
    • Lift the hard-drive assembly out of the computer base.
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
    • Place the hard-drive bracket on the NEW hard drive.
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
    • Place the hard-drive assembly on the computer base.
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
Ziellinie
Terrence15
Mitglied seit 18.12.2017
70.258 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 20
