Einleitung
In this guide, we will show you how to remove and replace the Hard Drive.
Was du brauchst
Remove the two screws that secure the hard-drive assembly to the computer base.
Slide the hard-drive assembly out of the hard-drive compartment.
Remove the two screws that secure the hard-drive bezel to the hard drive.
Pull the hard-drive bezel away from the hard drive.
Align the screw holes on the hard-drive bezel with the screw holes on the NEW hard drive and replace the two screws.
Slide the hard-drive assembly into the hard-drive compartment until it is fully seated.
Replace the two screws that secure the hard-drive assembly to the computer base.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
