Zum Hauptinhalt wechseln
Dell Inspiron 14 N4030 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Assembly: Schritt 2, Bild 1 von 1
    • Slide the hard-drive assembly out of the hard-drive compartment.
  3. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: Schritt 3, Bild 1 von 1
    • Remove the two screws that secure the hard-drive bezel to the hard drive.
  4. Dell Inspiron 14 N4030 Hard Drive Replacement, Removing the Hard Drive: Schritt 4, Bild 1 von 1
    • Pull the hard-drive bezel away from the hard drive.
  5. Dell Inspiron 14 N4030 Hard Drive Replacement, Align the Screw Holes: Schritt 5, Bild 1 von 1
    • Align the screw holes on the NEW hard-drive bezel with the screw holes on the hard drive and replace the two screws.
  6. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Hard-Drive Assembly: Schritt 6, Bild 1 von 1
    • Slide the hard-drive assembly into the hard-drive compartment until it is fully seated.
  7. Dell Inspiron 14 N4030 Hard Drive Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 1,130
