Zum Hauptinhalt wechseln
Dell Inspiron 14-3452 Motherboard Replacement
Was du brauchst
  1. Dell Inspiron 14-3452 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 14-3452 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Motherboard Replacement, Random Access Memory (RAM): Schritt 2, Bild 1 von 1
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
  6. Dell Inspiron 14-3452 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
    • Remove the one Phillips Head 3 mm #0 screw from the computer backing.
  7. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 14-3452 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the white and black antenna cables from the wireless card.
  8. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
  9. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Slide the wireless card out of the wireless card bay.
  10. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 14-3452 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Using your fingertips remove the speaker cable from the motherboard by pulling the white connector away from the socket.
  11. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Pry apart keyboard assembly slowly as keyboard cable will still be attached to the motherboard.
    • Use the blue spudger to pry apart the keyboard assembly from the bottom shell.
  12. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Disconnect the keyboard cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
  13. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 14-3452 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the I/O board cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
  14. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove the three Phillips Head 5 mm #0 screws.
    • Remove the one Phillips Head 3 mm #0 screw.
  15. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 14-3452 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Disconnect the display cable from the motherboard by pulling tape back and lifting connector latch.
    • Pull the display cable away from the motherboard.
  16. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Remove the power adapter cable from the motherboard by sliding the cable out of its socket.
  17. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Lift the motherboard off of the computer base.
  18. Dell Inspiron 14-3452 Motherboard Replacement: Schritt 18, Bild 1 von 2 Dell Inspiron 14-3452 Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Remove the four Phillips Head 3 mm #0 screws from the fan.
    • Remove the fan cable from the motherboard by sliding the cable out of the socket.
    • Lift the fan off of the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Baylor, Team S2-G2, Johnson Spring 2018 Mitglied von Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
BEFORE REMOVING TOP CASE: There are screws under the keyboard and one silver screw under the battery that have to be removed. This guide forgot to mention that.
Michael Hill - Antwort
Hello.
 Do you know how to expand the HDD memory of this same model 14-3452 ??;  I have a motherboard similar to the one in this guide and it does not have the connector for the hard disk integrated into it.
 I will greatly appreciate your help and response.
Lloyd Lopez -
Can the inspiron 15 3552 motherboard replace this model to have access to harddrive use?
kadianwilliams06 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 2,144
