Einleitung
Is the screen of your Inspiron 14-3452 broken? All you need is a spudger and a screwdriver in order to open up your laptop and replace its screen.
Was du brauchst
Remove the battery by sliding the battery release latch to the left.
Pull the entire battery away from the backing.
Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
Locate the blue RAM chip sitting in the RAM bay.
Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
Pull the RAM chip away from the memory-module slot.
The RAM chip is now fully detached and ready to be replaced.
Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
Remove the one Phillips Head 3 mm #0 screw from the computer backing.
Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
Using your fingertips remove the speaker cable from the motherboard by pulling the white connector away from the socket.
Use the blue Uspudger to pry apart the keyboard assembly from the bottom shell.
Disconnect the keyboard cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
Disconnect the display cable from the motherboard by pulling the tape back and lifting the connector latch.
Pull the display cable away from the motherboard.
Remove the power adapter cable from the motherboard by sliding the cable out of its socket.
Turn laptop over to access the screen hinge screws.
Remove the two Phillips Head 5 mm #0 screws from the two hinges.
Using your fingertips, gently pry up the inner edges of the display bezel.
Lift the display bezel off the display assembly.
After removing the bezel, locate the tab indicated in the pictures.
Lift the tab as shown in the pictures.
Lift the gold latch securing the display cable to the socket.
Pull display cable away from the socket.
