Einleitung
The reason your laptop is not connecting to the internet properly may be due to a worn-out or broken wireless card. This guide will show how to replace an old WiFi card with a new one.
Was du brauchst
Remove the battery by sliding the battery release latch to the left.
Pull the entire battery away from the backing.
Remove two Phillips Head 5 mm #0 screws holding the backing in place.
Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
Eine weitere Person hat diese Anleitung absolviert.
