Zum Hauptinhalt wechseln
Dell Inspiron 14-5447 Battery Replacement
Was du brauchst
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 14-5447 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 14-5447 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 14-5447 Battery Replacement: Schritt 4, Bild 2 von 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 3,059
