Einleitung
Remember, turning off your device and removing it from any power source before you start reparations is important for your safety to prevent any electrical shock. Tools included in the reparation include a plastic prying tool and if needed a tweezer to disconnect the cables attached to the keyboard.
Was du brauchst
Remove the two black 5.70mm Phillips#0 screws on the case's back.
Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
Use the black, plastic flap on the left side to pull the battery out.
Slowly lift the flap up and the battery should slide out.
Locate the five small slits at the top of the keyboard.
Using a plastic opening tool, carefully pry each slit to loosen the keyboard.
Slide the keyboard towards the screen at an angle for removal.
Locate the two cable connectors. These connectors secure the cables to the laptop with small, securing flaps.
To release the cables, take each flap and flip them upwards to the unlocking position.
Pull both the cables out after unlocking and set aside the keyboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
