Zum Hauptinhalt wechseln
Dell Inspiron 1420 Display Replacement
Was du brauchst
  1. Dell Inspiron 1420 Display Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 1420 Display Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 1420 Display Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: Schritt 2, Bild 1 von 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: Schritt 2, Bild 2 von 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: Schritt 2, Bild 3 von 3
    • Use a spudger to pry the 6 rubber bumpers from the display.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
  3. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: Schritt 3, Bild 1 von 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: Schritt 3, Bild 2 von 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: Schritt 3, Bild 3 von 3
    • Gently pry the frame using a spudger.
    • Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
  4. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: Schritt 4, Bild 1 von 3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: Schritt 4, Bild 2 von 3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: Schritt 4, Bild 3 von 3
    • Use a spudger to loosen the frame from the top.
    • Lift up the black connector to detach the gold ribbon.
  5. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: Schritt 5, Bild 1 von 2 Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: Schritt 5, Bild 2 von 2
    • Pull directly up on the light blue tab.
  6. Dell Inspiron 1420 Display Replacement, VGA cable: Schritt 6, Bild 1 von 3 Dell Inspiron 1420 Display Replacement, VGA cable: Schritt 6, Bild 2 von 3 Dell Inspiron 1420 Display Replacement, VGA cable: Schritt 6, Bild 3 von 3
    • Squeeze the two metal clips located on the VGA cable.
    • Pull while squeezing the clips in order to remove the cable.
  7. Dell Inspiron 1420 Display Replacement, Isolating the Display: Schritt 7, Bild 1 von 3 Dell Inspiron 1420 Display Replacement, Isolating the Display: Schritt 7, Bild 2 von 3 Dell Inspiron 1420 Display Replacement, Isolating the Display: Schritt 7, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
    • Remove the metal brackets, one on each side, by gently pulling.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 2-4, Blackwell Fall 2014 Mitglied von USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 16
Insgesamt: 2,461
