Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Turn the computer over.
Loosen the two captive screws securing the hard drive cover and then remove the cover.
Remove the hard drive assembly using the pull-tab.
Remove the two screws securing the hard drive to the hard drive assembly.
Tighten the two screws to secure the hard drive to the hard drive assembly.
Place the hard drive assembly in the hard drive bay by aligning the tabs on the hard drive assembly with the slots in the bay and pressing the connector end down.
Replace the hard drive door and tighten the screws.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
