Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
  2. Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  3. Pull the Mini-Card antenna cables up through the slot in the computer base.
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  5. Disconnect the display cable from the connector on the system board and remove the display cable grounding screw.
    • Disconnect the display cable from the connector on the system board and remove the display cable grounding screw.
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Remove the three screws that secure the display assembly to the computer base.
    • Remove the three screws that secure the display assembly to the computer base.
  8. Lift the display assembly off the alignment posts on the computer base.
    • Lift the display assembly off the alignment posts on the computer base.
  9. Use the alignment posts to place the NEW display assembly on the computer base.
    • Use the alignment posts to place the NEW display assembly on the computer base.
  10. Replace the three screws that secure the display assembly to the computer base.
    • Replace the three screws that secure the display assembly to the computer base.
  11. Connect the display cable to the connector on the system board and replace the display cable grounding screw.
    • Connect the display cable to the connector on the system board and replace the display cable grounding screw.
  12. Route the Mini-Card antenna cables through the routing guides on the palm rest.
    • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  13. Thread the Mini-Card antenna cables through the slot in the computer base.
    • Thread the Mini-Card antenna cables through the slot in the computer base.
  14. Turn the computer over and replace the two screws that secure the display assembly to the computer base.
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Ziellinie
Terrence15
70.643 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 37
