Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the two screws that secure the hard drive assembly to the computer base.
  2. Slide the hard drive assembly to the right to disconnect it from the connector on the system board, then lift the hard drive assembly out of the computer base.
    • Slide the hard drive assembly to the right to disconnect it from the connector on the system board, then lift the hard drive assembly out of the computer base.
  3. Remove the four screws that secure the hard drive to the hard drive bracket.
    • Remove the four screws that secure the hard drive to the hard drive bracket.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Lift the hard drive out of the hard drive bracket.
    • Lift the hard drive out of the hard drive bracket.
  6. Replace the four screws that secure the hard drive bracket to the hard drive.
    • Replace the four screws that secure the hard drive bracket to the hard drive.
  7. Place the hard drive assembly in the computer base and push to connect the hard drive assembly to the connector on the system board.
    • Place the hard drive assembly in the computer base and push to connect the hard drive assembly to the connector on the system board.
  8. Replace the two screws that secure the hard drive assembly to the computer base.
    • Replace the two screws that secure the hard drive assembly to the computer base.
Ziellinie
Terrence15
70.653 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 34
Insgesamt: 293
