Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Remove the screws that secure the display assembly to the computer base.
Turn the computer over and open the display as far as possible.
Disconnect the antenna cables from the connectors on the Mini-Card.
Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
Connect the antenna cables to the connectors on the Mini-Card.
Replace the screws that secure the display assembly to the computer base.
2 weitere Personen haben diese Anleitung absolviert.
