Zum Hauptinhalt wechseln
Dell Inspiron 14R SE 7420 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
  2. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the screws that secure the display assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Open the Display: Schritt 3, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Disconnecting the Antenna Cables: Schritt 4, Bild 1 von 1
    • Disconnect the antenna cables from the connectors on the Mini-Card.
  5. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
  6. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Lifting the Display Assembly: Schritt 6, Bild 1 von 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 1 von 2 Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 2 von 2
    • Place the display assembly in position and replace the screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Connecting the Antenna Cables: Schritt 8, Bild 1 von 1
    • Connect the antenna cables to the connectors on the Mini-Card.
  9. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: Schritt 9, Bild 1 von 1
  10. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the screws that secure the display assembly to the computer base.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 336
