Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
  2. Remove the screws that secure the hard-drive assembly to the computer base.
    • Remove the screws that secure the hard-drive assembly to the computer base.
    • Make a note of the hard-drive cable routing and remove the cable from the routing guides.
    • Lift the hard-drive assembly along with its cable away from the computer base.
    • Pull the interposer to disconnect the hard-drive cable from the hard-drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Slide the hard-drive off the hard-drive bracket.
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
    • Connect the hard-drive cable interposer to the hard drive.
    • Place the hard-drive assembly in the hard-drive bay on the computer base.
    • Replace the screws that secure the hard-drive assembly to the computer base.
    • Route the hard-drive cable through the routing guides on the computer base.
    • Connect the hard-drive cable to the system-board connector.
Ziellinie
Terrence15
Mitglied seit 18.12.2017
70.198 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 20
