Zum Hauptinhalt wechseln
Dell Inspiron 14R-5421 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 14R-5421 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
Abschluss
Jared paiva
489 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S4-G4, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G4, Covino Spring 2018
UMASSD-COVINO-S18S4G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 575
