Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws on the base of the computer that secure the display assembly to the computer base.
  2. Disconnect the display cable and remove the screw from the system board.
    • Disconnect the display cable and remove the screw from the system board.
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
    • Note the routing of all the cables and remove them from their routing guides.
    • Hold the display while you remove the three screws that secure the display assembly to the computer base.
    • Lift and remove the display assembly from the computer base.
    • Using the alignment posts, place the NEW display assembly in position and replace the three screws that secure the display assembly to the computer base.
    • Route the Mini-Card antenna cables and display cable through their routing guides.
    • Route the antenna cables through the slot in the computer base.
    • Replace the screw and connect the display cable.
Ziellinie
Terrence15
Mitglied seit 18.12.2017
70.258 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 19
