Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Disconnect the USB/audio cable from the system board.
Remove the four screws that secure the hard drive assembly to the computer base.
Slide and lift the hard drive assembly out of the computer base.
Remove the four screws that secure the hard drive to the hard drive bracket.
Place the NEW hard drive in the hard drive bracket and replace the four screws that secure the hard drive bracket to the hard drive.
Slide the hard drive assembly into the computer base until it is fully seated.
Replace the four screws that secure the hard drive assembly to the computer base.
