Zum Hauptinhalt wechseln
Dell Inspiron 14z Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 14z Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Here is a Dell Inspiron 14z N411z with a defective hard drive.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Hard Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 14z Hard Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 14z Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  3. Dell Inspiron 14z Hard Drive Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 14z Hard Drive Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 14z Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
    • Slide the hard drive to the opposite end of the connector. This will free the connection.
  4. Dell Inspiron 14z Hard Drive Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 14z Hard Drive Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 14z Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
    • Remove the two Phillips screws on the right side,
    • and the two Phillips screws on the left side.
  5. Dell Inspiron 14z Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • The hard drive is now removed from the caddy and the replacement can be installed.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
oldturkey03
811.239 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
45 Mitglieder
700 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 12,831
