Zum Hauptinhalt wechseln
Dell Inspiron 14z N114z Hard Drive Assembly Replacement
Was du brauchst
  1. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • Follow the instructions in "Before You Begin".
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Sliding the Hard Drive: Schritt 2, Bild 1 von 1
    • Using the pull-tab, slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Lifting the Hard Drive: Schritt 5, Bild 1 von 1
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Align the Screw Holes: Schritt 6, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Placing the Hard-Drive Assembly: Schritt 8, Bild 1 von 1
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Sliding the Hard Drive Assembly: Schritt 9, Bild 1 von 1
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 14z N114z Hard Drive Assembly Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Ziellinie
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 154
