Zum Hauptinhalt wechseln
Dell Inspiron 14z-5423 Fan Replacement
Was du brauchst
  1. Dell Inspiron 14z-5423 Fan  Replacement, RAM: Schritt 1, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement, RAM: Schritt 1, Bild 2 von 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 2, Bild 1 von 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 3, Bild 2 von 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 5, Bild 2 von 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Fan  Replacement, Optical Drive: Schritt 6, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement, Optical Drive: Schritt 6, Bild 2 von 2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Fan  Replacement, Keyboard: Schritt 7, Bild 1 von 3 Dell Inspiron 14z-5423 Fan  Replacement, Keyboard: Schritt 7, Bild 2 von 3 Dell Inspiron 14z-5423 Fan  Replacement, Keyboard: Schritt 7, Bild 3 von 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 8, Bild 1 von 1
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 9, Bild 2 von 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 10, Bild 2 von 2
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 11, Bild 1 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 11, Bild 2 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 11, Bild 3 von 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Fan  Replacement, Palm Rest Assembly: Schritt 12, Bild 1 von 1
  13. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 13, Bild 1 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 13, Bild 2 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 13, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 14, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 14, Bild 2 von 2
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 15, Bild 1 von 1
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 16, Bild 1 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 16, Bild 2 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 16, Bild 3 von 3
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Fan  Replacement, Battery: Schritt 17, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement, Battery: Schritt 17, Bild 2 von 2
    • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
  18. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 18, Bild 1 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 18, Bild 2 von 3 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 18, Bild 3 von 3
    • Lift the tiny black tab and pull the battery out at a slight angle.
  19. Dell Inspiron 14z-5423 Fan  Replacement, Hard Drive: Schritt 19, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement, Hard Drive: Schritt 19, Bild 2 von 2
    • Lift up the bottom of the hard drive which is located at the bottom of the laptop.
    • Gently pull the drive out at an angle using your fingers.
  20. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 20, Bild 1 von 1
    • Using a J0 bit tipped screwdriver, remove the four 3 mm black screws on both sides of the hard drive bracket.
  21. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 21, Bild 1 von 1
    • Slide the hard drive out of the bracket.
  22. Dell Inspiron 14z-5423 Fan  Replacement, Wireless Mini Card: Schritt 22, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement, Wireless Mini Card: Schritt 22, Bild 2 von 2
    • Locate the wireless mini card at the top of the laptop.
    • It is next to the place where the optics drive used to be.
  23. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 23, Bild 1 von 1
    • Using a J0 tipped screwdriver, remove the 4 mm Phillips head screw.
  24. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 24, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 24, Bild 2 von 2
    • Gently, unlatch the black and white wires from the wireless mini card.
  25. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 25, Bild 1 von 1
    • At an angle, slide out the wireless mini card.
  26. Dell Inspiron 14z-5423 Fan  Replacement, Motherboard: Schritt 26, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement, Motherboard: Schritt 26, Bild 2 von 2
    • Gently pull the the blue ribbon upwards to disconnect the computer from the motherboard.
  27. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 27, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 27, Bild 2 von 2
    • Using a plastic opening tool, gently detach the coin cell battery from the foam glue.
    • The coin cell battery is underneath the optical drive.
  28. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 28, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 28, Bild 2 von 2
    • Using a J0 tipped screwdriver remove the 6 mm Phillips head screw located at the center of the laptop on the motherboard.
  29. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 29, Bild 1 von 1
    • Remove motherboard at an upward angle.
    • The coin cell battery and fan will be removed with the motherboard.
  30. Dell Inspiron 14z-5423 Fan  Replacement, Fan: Schritt 30, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement, Fan: Schritt 30, Bild 2 von 2
    • Flip the motherboard over.
    • Locate the red and yellow wires attached to the fan and gently detach them from the motherboard.
  31. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 31, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 31, Bild 2 von 2
    • Using a J0 tipped screwdriver remove the three 5 mm Phillips head screws that attach fan to the motherboard.
    • The fan base is labeled 1, 2, 3. Make sure you unscrew the screws in this order.
    • The screws are attached to the fan and will fully unscrew.
  32. Dell Inspiron 14z-5423 Fan  Replacement: Schritt 32, Bild 1 von 2 Dell Inspiron 14z-5423 Fan  Replacement: Schritt 32, Bild 2 von 2
    • Remove the fan from the motherboard by lifting upwards.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
john
215 Reputation
1 Anleitung geschrieben
CSU Fullerton, Team 2-2, Bruce Fall 2016 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Mitglieder
11 Anleitungen geschrieben
2 Kommentare
Hurrah, just used these instructions to replace my fan and have a beautifully silent working laptop again - thanks! I skipped steps 20-23, and it would have been useful to have a mention that thermal compound was necessary to make a good connection when replacing the heat sink - but all in all great clear instructions. One happy good-as-new laptop owner!
Tanya Cowan - Antwort
This guide was bloody marvellous! This was the first time I’ve opened a laptop by myself and it was quite a ride but a fun one the only struggle that I had was the bloody blue ribbon connecting to the motherboard other than that the rest was really easy to follow. Thank you so much for the guide and I hope I can some day be a contributor just as great as you random internet person ^^
waluilli - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 1,544
