Einleitung
You will need to purchase a keyboard in order to proceed with the replacement.
Was du brauchst
Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Lift the plastic yellow flap on the system board.
Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
Lift the keyboard off of the computer.
Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
2 weitere Personen haben diese Anleitung absolviert.
