Zum Hauptinhalt wechseln
Dell Inspiron 14z-5423 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: Schritt 1, Bild 1 von 2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: Schritt 1, Bild 2 von 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: Schritt 6, Bild 2 von 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: Schritt 6, Bild 3 von 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 10, Bild 1 von 3 Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 10, Bild 2 von 3 Dell Inspiron 14z-5423 Keyboard Replacement: Schritt 10, Bild 3 von 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Marisol
626 Reputation
4 Anleitungen geschrieben
CSU Fullerton, Team 2-2, Bruce Fall 2016 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 1,500
