Einleitung
The optical drive allows for users to play CD's and DVDs on the Dell Inspiron 14z - 5423. This easy step-by-step guide will help in replacing the optical drive.
Was du brauchst
Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Slide the CD/DVD drive on the side of the laptop out using your fingers.
Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
