Zum Hauptinhalt wechseln
Dell Inspiron 14z-5423 Optical Drive Replacement
Was du brauchst
  1. Dell Inspiron 14z-5423 Optical Drive Replacement, RAM: Schritt 1, Bild 1 von 2 Dell Inspiron 14z-5423 Optical Drive Replacement, RAM: Schritt 1, Bild 2 von 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Optical Drive Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 14z-5423 Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Optical Drive Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 14z-5423 Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Optical Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 14z-5423 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Optical Drive Replacement, Optical Drive: Schritt 6, Bild 1 von 2 Dell Inspiron 14z-5423 Optical Drive Replacement, Optical Drive: Schritt 6, Bild 2 von 2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
Abschluss
Marisol
626 Reputation
4 Anleitungen geschrieben
CSU Fullerton, Team 2-2, Bruce Fall 2016 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 674
