Einleitung
The RAM is a memory card that holds the operating system and applications in order for the computer to access data.
Was du brauchst
Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Eine weitere Person hat diese Anleitung absolviert.
