Zum Hauptinhalt wechseln
Dell Inspiron 15 3541 Battery Replacement
  1. Dell Inspiron 15 3541 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 15 3541 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Battery Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Allison
562 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Can you do a guide on how to change a CPU on this computer?
F0RS3 Topaz - Antwort
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
Vivek Goyenka - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 1,755
