Zum Hauptinhalt wechseln
Dell Inspiron 15 3541 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 15 3541 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 2 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15 3541 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Allison
562 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 3,338
