Zum Hauptinhalt wechseln
Dell Inspiron 15 3559 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15 3559 Display Assembly Replacement, Turn the Computer Over: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 15 3559 Display Assembly Replacement, Noting the Cables: Schritt 2, Bild 1 von 2 Dell Inspiron 15 3559 Display Assembly Replacement, Noting the Cables: Schritt 2, Bild 2 von 2
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3559 Display Assembly Replacement, Note the Display Cable Routing: Schritt 3, Bild 1 von 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3559 Display Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3559 Display Assembly Replacement, Lifting the Display Assembly: Schritt 5, Bild 1 von 1
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3559 Display Assembly Replacement, Installing the new Display Assembly: Schritt 6, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3559 Display Assembly Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3559 Display Assembly Replacement, Route the Display Cable: Schritt 8, Bild 1 von 2 Dell Inspiron 15 3559 Display Assembly Replacement, Route the Display Cable: Schritt 8, Bild 2 von 2
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3559 Display Assembly Replacement, Routing the Antenna Cables: Schritt 9, Bild 1 von 1
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Ziellinie
Terrence15
79.131 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 1,122
