Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
Peel the tape that secures the display cable to the palm-rest assembly.
Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
Open the palm-rest assembly at an angle and slide it off the display assembly.
Place the NEW display assembly on a clean, flat surface.
Place the palm-rest assembly on the display assembly.
Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
Route the antenna cables through the routing guides on the palm-rest assembly.
Connect the display cable and close the latch to secure the cable.
Route the display cable through the routing guides on the palm-rest assembly
Adhere the tape that secures the display cable to the palm-rest assembly.
